lilwood
Feb 10, 2016Aspirant
What modem do I need for R6250 - I didn't realised I'd need one!
I bought a Netgear R6250 at Christmas and have only just got round to opening the box. The instructions say to connect it to your modem but I don't have a modem, only the free router that TalkTalk sen...
- Retired_MemberFeb 18, 2016
What is the make and model # of your talk talk router. I'm guessing it's a wireless modem router that uses mobile data. If that's true then use r6250 in AP Mode connected to your TT
DexterJB
Feb 10, 2016NETGEAR Moderator
Hi @lilwood,
You have several options depending on how you want to setup your network. Do you want to replace your existing router? Do you you want to setup a separate network with the R6250? Or do you want to have a single network and setup the R6250 as an access point?
Dexter
Community Team
