kiba89
Apr 03, 2022Follower
What netgear router allows wifi region change?
Hi, i'm looking for a netgear router that allows the wifi region change (i live in Italy but i want to set USA). I have a netgear nighthawk R7500 bought in 2015 and it has this option in WiFi menu. C...
Apr 03, 2022Guru - Experienced User
So only a couple regions require the region to be locked. If its bought in the north america region, its locked to that region. EU doesn't lock their regions (as far as I'm aware). So unless that's changed, if you buy it for your Italy region, you should be able to change the region code.
michaelkenward
Apr 04, 2022Guru - Experienced User
