ugoran's avatar
ugoran
Follower
Mar 11, 2024
what product is similar to n300 wnr2000v5?
I have been looking for n33 wnr2000v5, but it it seems to be out of production.The only reason that I specifically wanted this router is that it was possible to turn wifi off without turning  the router off. Can anyone recommend a similar router that has this function?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Just about every Netgear router has that feature.
    It is usually the wifi On/Off LED on the front. Same as it is on the WNR2000v5
    For some routers you can do it with a web browser and the graphical user interface (GUI).
    The button is easiest. Look for a model with that feature.
