Becky87Thompson
May 22, 2024Follower
What works with ac1750?
Ok, for starters, the login for Netgear doesn't work period. I've tried them all and nothing is working. I want to change the password to our current Netgear Wi-Fi box. Has anyone solved this issue (s)? Please let me know. Thank y'all so much. God bless you.
You can always factory reset and reinstall if you can't get in.
to reset, put and hold reset for 7-15 seconds while powered on?
Becky87Thompson wrote:
Ok, for starters, the login for Netgear doesn't work period. I've tried them all and nothing is working.There are usually reasons why this happens.
I admire anyone who says "tried them all", but we don't know what they actually did and what happened.
In your case don't even know what Netgear device you are using.
ac1750 is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
