S-Warren
Aug 14, 2015Guide
What's The Best Netgear Wireless Wifi Router Available Today?
Netgear has so many products out right now it's diffiicult to know what's the best thing happening right now. Sometimes you just want the best regardless of cost but the most expensive doesn't always...
- Aug 15, 2015
S-Warren The R7000 (AC1900) really is the sweet spot for Netgear and Asus actually. Negear's latest R7000 firmware seems to be quite stable, (less complaints) and, also a variety of 3rd party firmware to choose. from . I have two of them, running 3rd party firmware. So far, so good, on the R7000 front. Try to select routers that have Broadcomm chipsets (which the R7000 is based on). They seem to be more stable and also, have better firmware. Check ou the wikidevi site for router info. Just plug in the router in upper right search bar.
S-Warren
Aug 14, 2015Guide
Thanks for the reply netwrks. Well I have a lot of devices logging into my AC1200 around 10 right now which includes Printers, HDTV's, Computers, Blu-ray DVD's and a PS4 but when my kids visit they will log in with they're cell phones and tablets and the number will jump to around 14 or 15. I haven't reached that number yet but I'm concerned how well the AC1200 will handle that many devices at once.
Thanks for the reply Kaveh300. I checked out the specs for the Nighthawk and it looks pretty kick azz. I think it will handle anythiong I can throw at it plus some. I like that it features both a 2.0 and 3.0 USB port and boasts up to 3.2Gbps 600+1300+1300 Mbps Wifi speeds across those 6 antennas. This model makes my mouth water, I'm going to buy it, lol.
netwrks
Aug 15, 2015Master
Word of advice. Do your homework on the 8000 and 7500 firmware and USB usage wise. It's best to check the forum first, or make sure you have an exchange policy..
