S-Warren
Aug 14, 2015Guide
What's The Best Netgear Wireless Wifi Router Available Today?
Netgear has so many products out right now it's diffiicult to know what's the best thing happening right now. Sometimes you just want the best regardless of cost but the most expensive doesn't always...
- Aug 15, 2015
S-Warren The R7000 (AC1900) really is the sweet spot for Netgear and Asus actually. Negear's latest R7000 firmware seems to be quite stable, (less complaints) and, also a variety of 3rd party firmware to choose. from . I have two of them, running 3rd party firmware. So far, so good, on the R7000 front. Try to select routers that have Broadcomm chipsets (which the R7000 is based on). They seem to be more stable and also, have better firmware. Check ou the wikidevi site for router info. Just plug in the router in upper right search bar.
Kaveh300
Aug 17, 2015Aspirant
It means the client need to be AC compatible. You can't expect the maximum speed out of an AC router if your laptop or any device your using has a G or N.
S-Warren
Aug 19, 2015Guide
Dang it I didn't even think of that. It makes perfect sense and none of my clients are AC compatible. What on earth was I thinking. lol Thanks Kaveh for pointing that out.
