rkamarowski
Oct 07, 2025Aspirant
Where can I find the driver for AC1750 R6400
I need to find the network driver for the AC1750 R6400. Can anyone help?
- Oct 07, 2025
Routers Do NOT have drivers.
WiFi and Ethernet adpaters have drivers. Refer to your PC Mfr or WiFI/Ethernet chip set brand/Mfr for drivers for there products.
rkamarowski
I meant, where on my Windows 11 PC can I find it???
- wcalifasOct 10, 2025Prodigy
Do you mean you can't find it on your wifi list of available networks? Or if you're already connected to it via wifi you just open a browser and type 192.168.1.1, or http://www.routerlogin.net and it will ask you for your login credentials you made when you first set it up. Hope that helps.
