josephg304's avatar
Jan 08, 2021
Where do I find Firmware Updates for the RBK50V2
I am searchiung for any firmware updates for my RBK50V2 WiFi router.  I can only find firmware updates for routers with the RBR and RBS model numbers.   When I try to uplopad this firmware pdate fo...
  • schumaku's avatar
    Jan 08, 2021
    RBK does designate a kit including one RBR router and one (or more) RBS satellite.
    josephg304 wrote:
    When I try to uplopad this firmware pdate for the RBR model to my router, it tells me that the firmware update is the incorrect file.
    Open and unpack the zip archive - only the respective img file can be uploaded. plemans referred to the correct firmware kits above.
