josephg304
Jan 08, 2021Tutor
Where do I find Firmware Updates for the RBK50V2
I am searchiung for any firmware updates for my RBK50V2 WiFi router. I can only find firmware updates for routers with the RBR and RBS model numbers. When I try to uplopad this firmware pdate fo...
- Jan 08, 2021
josephg304 wrote:I am searchiung for any firmware updates for my RBK50V2 WiFi router. I can only find firmware updates for routers with the RBR and RBS model numbers.
RBK does designate a kit including one RBR router and one (or more) RBS satellite.
josephg304 wrote:When I try to uplopad this firmware pdate for the RBR model to my router, it tells me that the firmware update is the incorrect file.
Open and unpack the zip archive - only the respective img file can be uploaded. plemans referred to the correct firmware kits above.
schumaku
Jan 08, 2021Guru - Experienced User
- josephg304Jan 16, 2021Tutor
Thank you. Much appreciated.
