Darkhorse26
Jun 09, 2024Aspirant
Where is my dashboard for Router (R6400v2)
I logged into netgear to access my dashboard. Where did it go? Haven't logged in for years. Got new internet provider and I need to update router and extender info. I downloaded the app on my android...
Jun 09, 2024Guru - Experienced User
Can you see the routers home page with a wired PC and web browser?
Are you referring to the Nighthawk app?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
- Darkhorse26Jun 10, 2024Aspirant
I disabled the random MAC address on my Pixel phone, and I can now login to the Netgear app. Thank you. This brings me to another question. I just switched to ATT fiber and they set up a new network with a new name. I reset my router and my attached devices are working, but the network is still showing as my old network name. Is the router detecting the new network even though the network has changed? Do I need to change any settings?
- FURRYe38Sep 12, 2024Guru - Experienced User
Any progress on this?
If it's working, don't need to change anything.
