Petomai2
Nov 05, 2021Tutor
Where is parental controls / domain blocking?
I am trying to find domain blocking or parental controls, or IP address blocking. I can't find this in my R6230 it seems to be hidden. I found Site blocking but that doesn't block HTTPS secure websit...
michaelkenward
Jan 06, 2022Guru - Experienced User
KevinLiT wrote:
Hello Petomai2,
I understand you like to find more information about site blocking with a utility like parental controls on your R6230. The good news is the R6230 supports Parental Controls.
Yes, but which type of parental controls?
It is some time since Netgear announced that it has withdrawn the free version of parental contols.
NOTICE: Live Parental Control Service based on Ope... - NETGEAR Communities
Live Parental Control service based on OpenDNS will no longer be supported on NETGEAR devices as of December 31, 2021 due to challenges in maintaining the product and low usage. Effective April 1st, 2021 NETGEAR will remove support for Live Parental Controls from the NETEGAR genie app and from updated versions of their firmware.
Petomai2
Jan 06, 2022Tutor
Thank you but I don't have a mobile device. I would like to set this up inside the router. I can navigate to 192.168.1.1 but can't find the parental controls.
