BKalis
Dec 18, 2015Aspirant
where is the PIN on my N900 WNDR4500 located?
- Retired_MemberDec 19, 2015
advanced wireless settings
BKalis
Dec 27, 2015Aspirant
Hello I purchase a new micrsoft surface pro 3 and when I try to set up my wifi connection with my Netgear n900 WNDR4500 my surface pro is asking for the PIN which is not on the label - please let me know where is can find the PIN for my N900
DarrenM
Dec 29, 2015Sr. NETGEAR Moderator
Hello Bkalis
here is a article on the WPS pin that the surface is asking for hope this helps.
http://kb.netgear.com/app/answers/detail/a_id/96
DarrenM
- BKalisDec 29, 2015Aspirant
Hi Darren
Thank you for your reply.
After much fiddling and push in the right direction I found the PIN for my Netgear N900,you have to sign into your account, go to setting, them advance setting, flip through some of the scroll downs and wa la, the PIN is listed. Tks B
