clarecarver's avatar
clarecarver
Which devices do I by for router for Satellite
get viasat hooked up and they told me I need a router and gave me this number 802.11 and that I need a doul band router can you tell me which ones would be suitable  - this is in a house note far awa...
  • TaterSalid's avatar
    TaterSalid
    Jan 03, 2019
    A friend has that one and loves it. Just be sure to get the version 2 model. It will say so on the package as v2. I think the 200NAS is version 2. This one should be plenty fast.
