maxarch
Aug 04, 2016Aspirant
which model of router have a wifi on/off button
i am looking to know witch are routter have a on/off swich for the wifi like this model NETGEAR Wireless-N 150 DSL
- AnonymousAug 04, 2016
Most routers have a wifi button to turn on and off wifi.
Pick a router you're interested in then locate the manual and check it.
maxarch
Aug 05, 2016Aspirant
I know I can go on the control panel with my computer and turn on and off the Wifi. What I meet it a physical button on the case that you can press to switch on and off the WIFI signal. For the moment I have a D-Link dir-615 router, I can turn on and off by going to the control panel change the setting reset the modem wait 1 min that it reboots. I want an easier methode.like the model NETGEAR Wireless-N 150 DSL have a physical button on the case.
Anonymous
Aug 05, 2016Read my post again slowy..............
- michaelkenwardAug 05, 2016Guru - Experienced User
@searay wrote:Read my post again slowy..............
Mine too.
To repeat, NETGEAR Wireless-N 150 DSL is not a modem model. It is a standard for wireless.
Perhaps you mean this one:
WNR1000 | WiFi Routers | Networking | Home | NETGEAR
It is the only N150 router in Netgear's current range. (That is an old and slow wifi standard.) The model number is WNR1000.
Start here:
Wireless Routers for Home | NETGEAR
Check the features you want. Consult the manuals for those that look good.
- aalexandrebetaAug 05, 2016Master
all Netgear router have an ON/OFF switch
Is that true for wifi? Or just the whole box?
I have an old wifi range extender that seems to lack this feature, which is understandable, but four other boxes have wifi on/off switches.
- maxarchAug 21, 2016Aspirant
OK so....
i have followed comment that was said.
First I have realized that most of you are from Europe, me I am in Canada, the law are not the same and here in not a requirement to have an on/off WIFIbutton on the cover for the router.I have done some research to be sure that all net gear rooter has an on/off button. I look at the model N150 and find a lot of places that said the N150 has this button. You can see it on this picture http://www.asbis.cz/netgear-n150-wifi-router-wifi-on-off-wps-and-power-button-cz-sk-hu-sl-ro-gui-_ies226001.jpg and I have seen it on other youtube review video.
I have ordered from Amazon.ca, https://www.amazon.ca/gp/product/B001UI4RTG?ref_=pe_1822470_153573050_E_Asin_Title. When I received it I was surprised to see that it did not have this feature. We can see in the picture that it is not there.
Is net gear having different standards for different countries ?
my new question is
What model in Canada has an on\off WIFI button ???- AnonymousAug 21, 2016
WNR1000V3 has the button from what I can see when referencing the Product Data sheet and it's picture.
- michaelkenwardAug 21, 2016Guru - Experienced User
Correct.
Unless Netgear makes crippled modems for Canada, it is clearly described on page 4 of the manual:
The button on the right-hand side at the front.
