maxarch
Aug 04, 2016Aspirant
which model of router have a wifi on/off button
i am looking to know witch are routter have a on/off swich for the wifi like this model NETGEAR Wireless-N 150 DSL
- Retired_MemberAug 04, 2016
Most routers have a wifi button to turn on and off wifi.
Pick a router you're interested in then locate the manual and check it.
Retired_Member
Aug 05, 2016Read my post again slowy..............
michaelkenward
Aug 05, 2016Guru - Experienced User
@searay wrote:Read my post again slowy..............
Mine too.
To repeat, NETGEAR Wireless-N 150 DSL is not a modem model. It is a standard for wireless.
Perhaps you mean this one:
WNR1000 | WiFi Routers | Networking | Home | NETGEAR
It is the only N150 router in Netgear's current range. (That is an old and slow wifi standard.) The model number is WNR1000.
Start here:
Wireless Routers for Home | NETGEAR
Check the features you want. Consult the manuals for those that look good.
- aalexandrebetaAug 05, 2016Master
all Netgear router have an ON/OFF switch
- michaelkenwardAug 05, 2016Guru - Experienced User
Is that true for wifi? Or just the whole box?
I have an old wifi range extender that seems to lack this feature, which is understandable, but four other boxes have wifi on/off switches.
all the Netgear modem router I own have that feature!
What do you look for as your future router?
