maxarch
Aug 04, 2016Aspirant
which model of router have a wifi on/off button
i am looking to know witch are routter have a on/off swich for the wifi like this model NETGEAR Wireless-N 150 DSL
- Retired_MemberAug 04, 2016
Most routers have a wifi button to turn on and off wifi.
Pick a router you're interested in then locate the manual and check it.
michaelkenward
Aug 05, 2016Guru - Experienced User
Is that true for wifi? Or just the whole box?
I have an old wifi range extender that seems to lack this feature, which is understandable, but four other boxes have wifi on/off switches.
aalexandrebeta
Aug 05, 2016Master
all the Netgear modem router I own have that feature!
What do you look for as your future router?
- Retired_MemberAug 05, 2016
Voice command would be nice....also the clapper ....clap on ...clap off
- aalexandrebetaAug 05, 2016Master
Before implementing this feature there are more urgent matter to attend such as
Readyshare direct config thru the OS and truly multi-user
Netgear Genie complete rework, lighter more efficent and mapping the entire network
LAN config and QoS
are among the urgent stuff to solve!
