maxarch
Aug 04, 2016Aspirant
which model of router have a wifi on/off button
i am looking to know witch are routter have a on/off swich for the wifi like this model NETGEAR Wireless-N 150 DSL
- Retired_MemberAug 04, 2016
Most routers have a wifi button to turn on and off wifi.
Pick a router you're interested in then locate the manual and check it.
michaelkenward
Aug 21, 2016Guru - Experienced User
Correct.
Unless Netgear makes crippled modems for Canada, it is clearly described on page 4 of the manual:
The button on the right-hand side at the front.
maxarch
Aug 22, 2016Aspirant
Definitely do not have those buttons on the router I have ordered.
maybe it is not the v3
I am into the return process with Amazon.ca
- michaelkenwardAug 22, 2016Guru - Experienced User
maxarch wrote:maybe it is not the v3
That seems likely. The newest version is v4.
JWNR2010v5 N300 Wireless Router User Manual - N150_N300_Wireless_Router_UM_EN.pdf
No sign of a wifi button in the pictures of that one:
Generic_N150_N300_Wireless_Router_QSG_Color_08Aug2014.pdf
Maybe Netgear is removing this feature from new devices.
