kebinheds
Apr 11, 2022Follower
Which Netgear router buy?
Hi there, i have virgin media 100mbps contact and hub3 as main router. From that i run cat7 cable to living room downstairs, where is netgear r6220 with tv and home cinema hanged on.
I have another cat7 cable running from hub3 to my office/cave. I m happy with netgear ant nighthawk app, so i would like another netgear router for my office to run 2 gaming computers and printer by wire as well as to spread wifi upstairs.
Here is question coming. Which netgear router new or second hand would be best for my case please? I would like to see wifi6 and tri-band. Terace house from concrete, 10x25m including garden.
Budget is £100-£200 ish.
Thank you.
1 Reply
Depending on your goals budget. The WAX204 has been on sale recently for really cheap. Not sure in the UK but in NA its been less than $50
Otherwise search on amazon for netgear renewed and you'll find a few pretty solid deals.
