YelniPeto
Jul 02, 2021Follower
Which Netgear Router
I want to buy a router. Wirecutter.com says get the Netgear r7000p. I’ve heard Netgear makes some good stuff, so I checked them out and holy crap do they make a lot of routers that all seem the sam...
Jul 03, 2021Guru - Experienced User
Your home is roughly 3000sqft? that correct? (20ft x 50ft=1000sqft x 3 stories)
If so, I'd actually look at a renewed (not new) RBK43 on amazon. Its a little more than your current budget but would cover the whole home better than a single solution.
