axpresbom
Dec 02, 2021Follower
Which Netgear Router
Black Friday is almost here and I want to buy a router. Wirecutter.com says get the Netgear r7000p. I’ve heard Netgear makes some good stuff, so I checked them out and holy crap do they make a lot ...
Dec 02, 2021Guru - Experienced User
If i had to choose a single router solution, I'd either go with an R7800 renewed.
If I was thinking possible mesh, I'd be looking at the RBK43 renewed.
either system is pretty rock solid. A bit out of the price range but worth it IMO.
