bingo19
May 24, 2018Apprentice
Which router to choose now ?
Hello,
By chance, I compared the wan bandwith of my R6220 and WNR2000v5 connected alternatively to a VDSL modem set in bridge mode (and in LAN by Ethernet). There is no doubt that my WNR2000v5 has ...
- May 25, 2018
Who knows. I don't pay much attention to speedtests. I am more interested in using the hardware than making measurements. If it works as expected, I'm happy.
Maybe a more technical user can help you.
My point was that the R7800 is likely to deliver the same speed as the XR500, which you listed, and at a much lower price.
bingo19
May 25, 2018Apprentice
Hello,
Thanks for your reply. Do you think the R7800 won't have the same behavior as the R6220 (I mean the less wan throughput) ? I am worried about since I didn't firstly paid attention to that point.
michaelkenward
May 25, 2018Guru - Experienced User
