Chosenusername
Jul 09, 2016Aspirant
Which routers support the Time Machine feature?
Hello! I'm looking for a router that supports the Time Machine feature for someone else. Now I know that the Nighthawk R7000 router does since I'm able to find a tutorial in the Internet. The X6 ...
- Jul 11, 2016
Welcome to the community!Most of the newer model will support that feature but it's also best to check their manuals for accuracy.
Thanks!
ElaineM
Jul 11, 2016NETGEAR Employee Retired
Thanks!
Chosenusername
Jul 12, 2016Aspirant
Hi Elaine,
thank you!
Benjamin
