AmberSmith
Mar 07, 2022Aspirant
Why Can't i access this Website?
Hello Members, I'm attempting to open this website, https://stitchingpure.com, but fails every time to open seems like armor block this page. All of the other websites are up and running. I tried o...
Mar 08, 2022Guru - Experienced User
Are you sure its armor blocking it?
Are you getting a notice from armor saying its blocked it? .
https://www.bitdefender.com/consumer/support/answer/28376/
AmberSmith
Mar 08, 2022Aspirant
Yes I am sure this is an armor blockage because I have also faced the same issue in past but with another company router. Please give some solutions!!
- michaelkenwardMar 09, 2022Guru - Experienced User
Please give some solutions!!Hard to do that without knowing what Netgear hardware you are using what the browser is, or anything useful about your network. But that might not be relevant.
In which case it probably has nothing to do with your unknown (to us) router.
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
- plemansMar 09, 2022Guru - Experienced User
Again, you haven't said how you know its armor. Is the screen saying "blocked by armor"?
Does it work if you shut off armor?
"another company router" doesn't tell us a whole lot. You don't even say if its a different companies router or if you mean a different netgear router. Details are key.
You can unblock through armor following this guide.
https://kb.netgear.com/000061032/NETGEAR-Armor-is-blocking-URLs-that-I-want-to-access-what-do-I-do
AmberSmith wrote:
Yes I am sure this is an armor blockage ...
Try this:
Search - NETGEAR Communities – Why Can't i access this Website
