missouriupser
Jan 11, 2022Aspirant
Why does my new iphones not get internet when they show connected to the wifi?
My family members that have gotten new Iphones connect to our home wifi set up but get no internet service and I cannot figure this one out! Has anyone else had this issue? Please help! Thanks...
michaelkenward
Jan 14, 2022Guru - Experienced User
If we are talking about the D3600 modem/router in your footer, can you tell us what firmware you have on it?
What messages do they see when they try to connect to the wifi?
Are you using an SSID or passwords on the router with characters that iOS does not like?
Have they told their devices to forget any previous connections to this SSID and to set up the connection from scratch?
If you do have the D3600, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
DSL Modems & Routers
- missouriupserJan 14, 2022Aspirant
The box says Netgear N600 wfi dual band router.
- michaelkenwardJan 14, 2022Guru - Experienced User
That's a wifi speed, not a model number. Look for that in the label.
- missouriupserJan 15, 2022Aspirant
The firmware I have is V1.0.1.42
I'm sorry I'm so illiterate when it comes to computer and router knowledge!
Thank you!
Heath
- michaelkenwardJan 15, 2022Guru - Experienced User
You now list the WNDR3400v3. If that is it, you have the latest firmware!
Not your fault. It happens all the time. Netgear doesn't help by using those wifi speeds all over the place.
But we now need to know what the modem is in front of the router. I ask because these can be modem routers with their own wifi. And that can cause all sorts of chaos.
We still don't know what messages people see when they try to connect to the wifi.
