BOSU
Jun 10, 2024Aspirant
Why does my WNDR3700v3 Internet Light stays amber even though confirmed Internet Connected ?
As per WNDR3700 Manual the Internet Light definitions are Solid Green : An IP address has been received; ready to transmit data. Solid Amber : The Ethernet cable connection to the modem has been ...
Jun 10, 2024Guru - Experienced User
Is the connection to the host router LAN port supporting of 1G? I presume if this is the case and the cable between the host router and 3700 is good, cat5E or cat6, and connected to the WAN port on the 3700 while in AP mode, the LED should return green.
Does the status on the WAN port display 100Mpbs or 1000Mbps on the 3700?
Check the 3700s user manual for LED behaviors and information.
