BOSU
Jun 10, 2024Aspirant
Why does my WNDR3700v3 Internet Light stays amber even though confirmed Internet Connected ?
As per WNDR3700 Manual the Internet Light definitions are Solid Green : An IP address has been received; ready to transmit data. Solid Amber : The Ethernet cable connection to the modem has been ...
BOSU
Hi !
Thanks for input !
The connection to host Router from WNDR3700 should support 1G
(I have Cat5e cable as fixed install in house) and is connected to WAN port on WNDR3700.
When connecting to LAN Ports I get a Solid Green Light (blinking with activity) so also implies 1 Gbps
As per 3700 Manual Internet LED should be Green if Properly connected with IP address allocated (See enclosed)
These Internet LEDs does not seem to indicate speed (10/100 or 1000) as
done for LAN LEDs rather only connectivity.
Nor able to find anything additional in user manual that explains Internet LED being solid (with activity) amber
that explains this.
So not sure if this is a Manual documentation omission or there is some issue with my setup ?
Regards
/Bo
PS If I move host router connection from WAN Port to a LAN port on WNDR3700v3,
then LAN light indicated Solid Green (blinking with activity).
So seems to confirm I have 1000 Mbps (1G) connectivity between host Router and WNDR3700
Jun 10, 2024Guru - Experienced User
Sounds like this older model was supported in AP mode on it's LAN port then.
