major82's avatar
major82
Why won't my printer connect?
I changed my router password. My wireless HP ENVY 5530 all-in-one printer is not recongized by the wireless network and does not print. My computer does not recognize the printer on the wireless netw...
  • DexterJB's avatar
    DexterJB
    Jan 19, 2016
    Hi @major82,
    If you have successfully changed the password for your wireless network, your wireless devices may have saved the old password. You may have manually remove/forget the old settings for your wireless network and reconnect using the new password.
    For the iPad:
    Settings > Wi-Fi > Look for the name of your wireless network > Select the 'i' icon > Select Forget This Network > Then try reconnecting. It will prompt you for your new password.
    For the computers:
    Control Panel > Network and Sharing Center > Manage Wireless Networks > Select the name of your wireless network > Right click > Remove network. Then try reconnecting to the Wi-Fi network like you normally would.
    Dexter
    Community Team
