rebeccabray
Apr 29, 2016Aspirant
Why won't my printer connect?
I am trying to connect my HP Officejet 7410 wirelessly (new router alreadyconencted to computer ... now trying to print). When I go through the wireless set up, the printer finds the new router, it r...
- Apr 29, 2016
Sounds like you'are almost there. Now give the printer fixed ip address.(assign an ip address to the printer0
This'll make sure printer always use smae ip address not causing ip address conflict with other devices. Then
Power off/on both printer and router. It should do it. You dl test print from printer property tab. If still won't print
then two things your deviceS which want to use the printer should have printer driver installed, and make sure
the printer is seen at the printer and devices section in the control panel. If not add that printer. second, ping the
printer address to make sure the printer is responding. This confirms printer is on-line and ready to accept print
jobs. When printer has nothing to print, it'll go to sleep to save power. When printer job comes it'll wake up and
start printing. Also if the printer is NFC, Airprint capable it work using that feature from device like iPhone, etc.
rebeccabray
Thank you! It connects, but I cannot get my printer to connect "online". Will continue to mess around with things. Thanks! Becky
VE6CGX
Apr 29, 2016Master
- rebeccabrayApr 29, 2016Aspirant
Printed and we are good to go. Thanks! becky
