toao
Oct 18, 2015Aspirant
Why won't my printer connect?
My HP Deskjet 3520 works great when I wirelessly connect it to my AT&T router. I am changing service and am trying to connect it to my Netgear WNDR 3400 and my cable modem. I have gone into my HP s...
- Oct 25, 2015
It took me forever, but it was actually pretty simple. I simply had to uncheck the box for wireless isolation on my router manager. I just lucked up and tried this and it worked!
TheEther
Oct 18, 2015Guru
Rerun the Add Printer wizard on your computer. Make sure your printer is on when you do this. Once you have completed this, you can safely remove the old printer instance from Devices and Printers.
- toaoOct 25, 2015Aspirant
When I try to add a printer in control panel, and I try to find a network printer, it won't find my printer.
- TheEtherOct 25, 2015Guru
It sounds like your printer is using the wireless guest network. If that's what you intended, great, you're done. If not, then you may want to rejoin the printer to the internal network.
