Etrauger
Feb 01, 2022Follower
Wi-Fi extender n300.
I just got Verizon 5g router installed today. My extender would work on a ring camera about 30 ft away. Now it says the internet connection is poor. Do I need a newer extender to reach the camera bec...
Feb 01, 2022Guru - Experienced User
there's a difference between 5ghz and 5g.
What actual verizon router did you buy/add?
did you setup the old extender using wps or using the installation assistant?
