Nemo-2000's avatar
Nemo-2000
Wi-Fi extender upgrade query
Currently my Netgear router has 802.11n Wifi, as does my Netgear Extender. I am about to upgrade to a router with 802.11ac, so I was thinking of replacing my Extender by a EX3700 model in order to increase the WiFi speed.
The Extender is needed to feed a laptop in another part of the house, but that only has 802.11n capability. In due course I will replace it with one with 802.11ac, but in the meantime how will the system work? Will the Extender talk 'ac' to the router and then 'n' to the laptop, or simply 'n' from end to end?
Even if the latter, will the end-to-end speed still be better than currently (approx 135mbps only to the laptop)?
  • plemans's avatar
    What actual router do you plan on buying?
    What extender do you plan on getting? The EX3700?
    What wireless chip is in the laptop? Does it have 5ghz? or only 2.4ghz?
    Extenders by their very nature, drop speeds 50% of what they recieve (except the tribands).
    So its something to keep in mind.
    If you're planning on getting a new router and a new extender, maybe a better option is to check into a mesh system that offers seamless roaming and the ability to add satellites as needed.
    • Nemo-2000's avatar
      Nemo-2000
      The current router (DG2200) is sited upstairs with wired connections to most devices, but the laptop is used downstairs. The WiFi signal from router to laptop is about 3/4 strength and not very stable, hence the use of an extender (currently WN3000RP). The result is a strong stable signal, but obviously a 50% drop in WiFi speed.
      I am moving to BT as ISP and will be sent a new Smart Hub 2 router. I am hoping that its WiFi signal to the laptop may be strong enough not to need an Extender, in which case no problem. However, if an extender is still necessary, then I would like to upgrade to a 3700 in order to increase the spead on the Extender to laptop link, on the basis that 50% of (say) 650Mbps is at least better than 50% of 350 Mbps :-)
      AFAIK the laptop is only capable of 2.4 GHz. Although it will get replaced eventually by one with 802.11ac, at the meantime I would like to get at least some improvement in WiFi spead if at all possible, hence the idea of an extender upgrade at modest cost.
      • plemans's avatar
        an upgrade to a dual band extender might help a little if you're using fastlane. Otherwise if you're not, the 2.4ghz will still use the same chip/link as the prior extender since its based on 2.4ghz.
