airman105's avatar
airman105
wi fi internet on cell phone
Router (WNR2000v5) is working fine (Roku and PC hooked up) but my cell phone is giving this error while connected to the wi fi and trying to surf web, DNS_PROBE_FINISHED_NXDOMAIN. Any ideas? THanks.
  • ITs an LG Transpyre (android). Got everything going. Not sure what fixed it. :) Thanks for the support though.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Welcome to the community, airman105
    What is your phone? Is this Android or an iOS device?
    Have you tried restarting your phone and try to reconnect to the router?
    Do you have a static IP address and DNS assigned on your phone?
    • airman105's avatar
      airman105
      • ElaineM's avatar
        ElaineM
        You're welcome and thank you for the update!
