MagicFriend
Jul 31, 2021Follower
Wi-Fi Problem
Hi, I wondered if you could please help me with a problem? I have a customer with a 350+ year-old house, which has thick walls, suspended ceilings, and plenty of steel through the stairwell. ...
michaelkenward
Aug 01, 2021Guru - Experienced User
MagicFriend wrote:
Now, Sky have been out because this dead zone has some of their equipment. They have run a Cat5e cable directly from the router to their TV box in the dead zone. I was about to run some Cat6a cable alongside it, but firstly I couldn't find a Wi-Fi unit with an ethernet input, and secondly I thought that I would speak to you guys first and ask for help.
You should not need to run an Ethernet cable alongside Sky's Cat5e cable if it is simply an Ethernet cable feeding from a router into an Ethernet port on the TV box. You can just interrupt the existing cable, insert a cheap switch and plug the TV into that. You can then plug an wireless extender into another outlet port on the switch and use it in wireless access point (AP) mode.
These are dead cheap:
Gigabit Unmanaged Switch Series - GS105 | NETGEAR
Less then £20 in the UK. Other brands could be even cheaper.
Just about any "wifi extender" – what you call a "Wi-Fi broadcast unit" – should plug into that and provide wifi in what sounds like a small area. Again, you can pick up a Netgear device for <£30, possibly even less for other brands and no-name knock offs.
I am surprised that you could not find "a Wi-Fi unit with an ethernet input". Amazon lists them by the shelf load. (Buy from your preferred seller.) Search for "WiFi Repeater" and pick something that claims to work in AP mode. Most do.
antinode
Aug 02, 2021Guru
> [...] insert a cheap switch and plug the TV into that. You can then
Yes, you could get an extender which works as a WAP, and, if it
doesn't have enough Ethernet ports, then you could get a network switch
to give you more Ethernet ports. Or, you could get a purpose-built WAP
which has everything you want in one box. Or, you could get a router
which can be configured as a WAP, and get everything you want in one
box.
As usual, many things are possible. As my mama told me, "you better
shop around."
