Alr72127
Apr 25, 2022Follower
Wi-Fi Speed?
I have fiber internet with 1 gigabit speed. Just purchased the Nighthawk AC1750 Model R6350? Running speed tests but am only getting 111.42 Mbps download, 91.76 Mbps upload, and ping 20 ms. Do I need a stronger router??
1 Reply
The R6350 is a pretty base model AC device. Its not going to have the greatest performance if you have gigabit speeds.
But you should get more than 111mbps.
Make sure you're testing over the 5ghz. Also make sure to test a wired speed to ensure you're getting full speed. AC isn't going to get close to maxing out gigabit but you should get faster than that.
