mylaliz
Feb 02, 2019Initiate
Wi-fi won't work! Please help!
My wi-fi won't work. Netgear Genie keeps saying it isn't enabled. I've rebooted the router, the modem, and the computer. I've checked that the wi-fi button on the router is on (tried turning off and ...
- Feb 03, 2019I ended up biting the bullet and buying another router. The new one works fine so the reset button probably would've worked. I appreciate your help!
michaelkenward
Feb 03, 2019Guru - Experienced User
Can you tell us what the Netgear router is? The model number?
