mylaliz
Feb 02, 2019Initiate
Wi-fi won't work! Please help!
My wi-fi won't work. Netgear Genie keeps saying it isn't enabled. I've rebooted the router, the modem, and the computer. I've checked that the wi-fi button on the router is on (tried turning off and ...
- Feb 03, 2019I ended up biting the bullet and buying another router. The new one works fine so the reset button probably would've worked. I appreciate your help!
wcalifas
Feb 03, 2019Prodigy
When you say reset what kind of reset did you perform. You should do a hard reset by pressing the reset pinhole with a paper clip for 30 seconds while the router is on. That will set it back to defaults and you will start it from scratch just like it was when it was new. Did you try that?
mylaliz
Feb 03, 2019Initiate
