Upnorthguy_3
Nov 25, 2020Aspirant
WiFi access point set up
Trying Resurrect this router to expand the range of my Starlink WiFi . I forgot the passwords so I did A factory reset. Thru the iPhone nethear mobile app I am trying to configure this unit. I seem to...
wcalifas
Nov 26, 2020Prodigy
If you did a hard reset it should go back to factory default and the password should be password. Try getting into the router wired with a laptop.
Upnorthguy_3
Dec 15, 2020Aspirant
So I did this. It seems this router cannot connect to a wireless router, i think i has to be plugged in (like a previously had it with my cable modem (old house)). I was able to plug it into my desktop at home, connect it to my starlink router thru the PC which is connected to the starlink router.
Not sure this model has the functionality i need.........
- antinodeDec 15, 2020Guru
> So I did this. [...]
"this"? _What_?
Try to imagine how "Not sure" the non-psychics in your audience must
feel. Perhaps if you revealed what "the functionality [you] need" might
be, then you might get better advice. Hint: "expand the range of my
Starlink WiFi" is not a very detailed description of anything.> [...] It seems this router cannot connect to a wireless router, [...]
Probably true, in general.
> [...] I was able to plug it into my desktop at home, connect it to my
> starlink router thru the PC which is connected to the starlink router.If you think that that's a useful description of anything, then you
might want to think again. (Hint: If a device has different types of
Ethernet ports, then "connected to device" is not enough detail.)
