fred339
Oct 30, 2020Tutor
WiFi Access Point with DHCP server
I need to replace our DAP-2360 access points with one more current that will pass vulnerability scans. So, it needs to have a built-in DHCP server.
fred339
Oct 31, 2020Tutor
Yes, DAP-2360 is a DLink product. It was provided for reference so the question would be more complete.
re: "vulnerability scans" - just Google it. If one gets a lot of meaningful hits then one can be assured that it's a common term in the industry and might learn someting. It does get a lot of hits and it is a common term in the industry. The simple idea is that the replacement we're looking for needs to be up-to-date re: security.
"So" derives from the fact that the DAP-2360 has a built-in DHCP server and we've made use of it. Without it we'd have to change our architecture and our approach to a number of things that I need not enumerate.
The "nonsequitur" comment was unnecessary.
Yes, we know that most access points don't include a built-in DHCP server. So, we're asking the *product* experts if they know of any that are newer than the DAP-2360 which does have it.
This *is* the problem to be solved.
I could have written a longer explanation in the question but expect that would have resulted in a bunch of workaround ideas. That's not what I'm looking for. Either the device exists in someone's experience and knowledge or it does not. If it doesn't, no need to answer.
I take it that *antinode* doesn't know of one.
antinode
Oct 31, 2020Guru
> [...] meaningful hits then one can be assured that it's a common term
> in the industry and might learn someting. [...]
"common" and "specific" are spelled differently for a reason.
> [...] The simple idea is that the replacement we're looking for needs
Still too vague to be helpful.
I'd say that the actual problem to be solved might be the provision
of a usable DHCP server to the WAP clients. Whether the WAP itself
should be that server is a different question.
> that would have resulted in a bunch of workaround ideas. [...]
Probably. (Do you wonder why?) How much time did you save this way,
do you think?
> [...] we're asking the *product* experts [...]
Not here, you're not. You might try a more relevant forum:
https://community.netgear.com/t5/x/bd-p/business-wireless-for-business
