kevev
Nov 24, 2021Follower
WiFi Access Point
I have a dual band router at home which is connected to the internet by our local ISP Karoo (Kingston Communications). The braodband service and connection is Lightstream Fibre Optic and has been in ...
Nov 24, 2021Guru - Experienced User
You have a ton of options.
1. you could use a wireless extender. Most of them (not all) have an access point mode
2. you could use an old/new router. Most routers have some form of access point mode.
3. you could use a dedicated access point.
4. You could upgrade the router in the house and use the old one for the access point.
And all of this is before even getting to the specs you want for your device. :)
If it was me? I like having a backup router in case one fails. I'd be looking at just a router and running it in access point mode. That way if you're curent one fails or has issues, you have the other one you could swap in. A spare router has saved me lots of times :)
