dukeeastwood
May 12, 2022Tutor
Wifi and hardwired computer will not work at the same time
So, I have an old WNDR3300... today I bought a 5-port gigabit Ethernet switch; the point being, I want my computer connected to my modem directly and to also have wifi. Before I only had the wifi rou...
May 13, 2022Guru - Experienced User
What modem do you have?
If you have a modem only device, most ISP's only assign 1 public ip address. Meaning only 1 device can be connected to a modem (even if you use a switch). Some isp's will allow more but you have to pay for more than 1 ip address or pay for a business connection.
dukeeastwood
May 13, 2022Tutor
Interesting, this is what I was worried about; that it may be a problem like this.
the modem is the Spectrum E31U2V1 that comes from spectrum...
perhaps I could take the issue up with spectrum and see if they will simply admit it won't work.
- plemansMay 13, 2022Guru - Experienced User
You can go modem--->router---->switch/devices
- dukeeastwoodMay 13, 2022Tutor
i talked to spectrum today... they already told me the same thing you did... without a business account/business internet the switcher will not allow the signal to be split in such a way as I was attempting... I already took the switcher I bought back to the store and got a refund. Thank you, you actually saved me resetting the modem 30 more times like I did yesterday.
Might be worth checking into a better router.
The WNDR3300 was released in 2007 and isn't even gigabit.
Its going to bottleneck your whole network.
Might be time to retire it as 15 years is putting in its time.
