davidzemanek
Jun 18, 2017Aspirant
Wifi can take a while to connect
Sometimes, our devices will take a while to connect. If I power cycle the router, everything in the house will connect as soon as the router comes up. But if I leave the house and come back, while bot...
- Jun 27, 2017
Hi davidzemanek,
1. You can try changing the wireless channel.
2. You can also try resetting the router.
3. If the issue persists, you can re-flash the firmware then do a factory reset. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
davidzemanek
Jun 22, 2017Aspirant
It's an r6220. I'll try that later today and see if it works. Guessing the issue is that the router may struggle at times in the IP assignment process?
