davidzemanek
Jun 18, 2017Aspirant
Wifi can take a while to connect
Sometimes, our devices will take a while to connect. If I power cycle the router, everything in the house will connect as soon as the router comes up. But if I leave the house and come back, while bot...
- Jun 27, 2017
Hi davidzemanek,
1. You can try changing the wireless channel.
2. You can also try resetting the router.
3. If the issue persists, you can re-flash the firmware then do a factory reset. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
DexterJB
Jun 27, 2017NETGEAR Moderator
Hi davidzemanek,
Dexter
Community Team
DexterJB
Jul 05, 2017NETGEAR Moderator
Hi davidzemanek,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
