loz63
Nov 13, 2016Follower
wifi channel
I have a netgear wifi router model WNDR3700v5 which untill yesterday was working fine , it offered 2 channels from new , a 2.4 ghz and a 5ghz. my set up for the last 9 months has been on the ...
- Retired_MemberNov 14, 2016
forget the app use web browser and login to router or
Press reset until power LED flashes the default SSID should then be visible ( see router Label ) if not replace router
Retired_Member
Nov 14, 2016forget the app use web browser and login to router or
