Olufunke
Oct 06, 2021Follower
Wifi connected, no internet.
I just bought this router today. I have registered the MAC address to my housing unit's internet network, but still unable to access the internet either through wifi or ethernet. Each time I go to ...
michaelkenward
Oct 07, 2021Guru - Experienced User
Olufunke wrote:
I just bought this router today. I have registered the MAC address to my housing unit's internet network ...
What sort of Internet is this? Does it come from a router of some sort?
Have you asked the manager, or other residents, if there are any special settings that you need to use the network?
Don't expect much from the R6120. It is a very basic router. According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer Internet services and most modern network hardware.
If the housing unit's Internet network is faster than 100 Mbps you are throwing away some of that speed.
