ShreeRP
Feb 27, 2017Aspirant
wifi connectivity disconnects intermediatly
we are facing wifi disconnecting itermediatly and get dificulties to reconnect ... and afts er restart whole network devices the it connects again
- Mar 05, 2017
Hi ShreeRP,
1. What is the firmware version of the device?
2. Please try changing the wireless channel of the router. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/1027
3. Does the issue persist on both wired and wireless devices?
4. You can also try performing a factory reset. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
JohnRo
Feb 27, 2017NETGEAR Employee Retired
Hello ShreeRP,
Welcome to the community!
I'd like to know the model number of the device you are having issues with.
Thanks,
- JohnRoMar 02, 2017NETGEAR Employee Retired
Hi ShreeRP,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- ShreeRPMar 03, 2017Aspirant
Dear JohnRo,
We have WNR 614 and R 6220
- DexterJBMar 05, 2017NETGEAR Moderator
Hi ShreeRP,
Dexter
Community Team
