Cram
Jan 25, 2016Aspirant
WIFI devices see WIFI but do not connect - R6300 -- firmware V1.0.2.78_1.0.58
Hello, I have loocked up on many treads but could not find a working solution for me. I have a R6300 v1 with firmware V1.0.2.78_1.0.58 and it was shut off last night by accident. Since then I...
- Jan 25, 2016
Thank you very much!
Working now!
Had to do a complete manual reset of the parameters.
I guest some paramters in my saved file was currupted or something.
Problem solved!
Cram
Also....
Forgot, the TV and printer do not connect as well.
- Retired_MemberJan 25, 2016
reset router to default settings, IFusing default settings it still doesn't work , replace it.
- CramJan 25, 2016Aspirant
Thanks
I will try that now and let you know.
Working now!
Problem solved!
- chris20023333Feb 18, 2016Aspirant
why does the green light keep flashing for no reasion
