Cram
Jan 25, 2016Aspirant
WIFI devices see WIFI but do not connect - R6300 -- firmware V1.0.2.78_1.0.58
Hello, I have loocked up on many treads but could not find a working solution for me. I have a R6300 v1 with firmware V1.0.2.78_1.0.58 and it was shut off last night by accident. Since then I...
- Jan 25, 2016
Thank you very much!
Working now!
Had to do a complete manual reset of the parameters.
I guest some paramters in my saved file was currupted or something.
Problem solved!
chris20023333
Feb 18, 2016Aspirant
my netgear R6300 will not work cause the green light keeps blinking does anyone know why
DexterJB
Feb 20, 2016NETGEAR Moderator
Hi @chris20023333,
1. Which light on the device is it?
2. Are all devices affected?
3. Have you tried resetting the device?
Dexter
Community Team
- Retired_MemberFeb 20, 2016
corrupt Firmware I beleive...................... check the manual
