Cram
Jan 25, 2016Aspirant
WIFI devices see WIFI but do not connect - R6300 -- firmware V1.0.2.78_1.0.58
Hello, I have loocked up on many treads but could not find a working solution for me. I have a R6300 v1 with firmware V1.0.2.78_1.0.58 and it was shut off last night by accident. Since then I...
- Jan 25, 2016
Thank you very much!
Working now!
Had to do a complete manual reset of the parameters.
I guest some paramters in my saved file was currupted or something.
Problem solved!
DexterJB
Feb 20, 2016NETGEAR Moderator
Hi @chris20023333,
1. Which light on the device is it?
2. Are all devices affected?
3. Have you tried resetting the device?
Dexter
Community Team
Retired_Member
Feb 20, 2016corrupt Firmware I beleive...................... check the manual
