Lo7us's avatar
Lo7us
Follower
Sep 06, 2017
wifi disconnecting on both 2.4g and 5g
Wired connection works fine and my genie says the wifi is fine but none of my devices can see either wireless broadcasting.  I can fix this for about 5 minutes by resetting the router but it always r...
  • DexterJB's avatar
    DexterJB
    Sep 12, 2017
    Hi Lo7us,
    1. Have you tried using another firmware version?
    2. You can also try re-flashing the firmware the do a factory reset.
    Dexter
    Community Team
