dturn9
Mar 03, 2022Aspirant
Wifi Does Not Work, but Ethernet Does
At random times, I am still connected to the Wifi, however there is no internet connection. Addtitionally, if I leave the network, I cannot rejoin. The ethernet still works fine. Turning the router o...
michaelkenward
Mar 04, 2022Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Having two routers on a network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
dturn9
Mar 04, 2022Aspirant
The firmware verision I most recently updated to is V1.0.4.122. The modem in front of the router is a Netgear CM500.
- FURRYe38Mar 04, 2022Guru - Experienced User
The CM500 is not a router, it a modem only. No built in router or WiFi.
Do you have a wifi router connected to the CM modem? If not, you'll need to install a WiFi router behind the CM modem, then connect your wifi devices to this router....
- wcalifasMar 04, 2022ProdigySince you already have a gateway modem you must set the R6400 as an access point and turn off its dhcp because you'll end up getting a double nat which gives you those problems.
- michaelkenwardMar 05, 2022Guru - Experienced User
wcalifas wrote:
Since you already have a gateway modem ....The CM500 is not a gateway modem. Plain cable modem.
